VALVE SPRING ?
Old Jul 12, 2006 | 08:16 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
VALVE SPRING ?
ok, when i started rebuilding my heads i had a different cam in mind. original cam called for springs with 105lbs at seat and a rate of 417lbs.
cam im using calls for 91lbs seat and rate of 300lbs.
heads are built. will cam be ok with the stronger springs ?
its a comp extreme energy hyd roller cam.
Old Jul 12, 2006 | 11:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yep, shouldn't cause a problem.
your stronger spring, that's still a single spring? If it's a double make sure to remove the inner spring for the break-in. If it's a single, with the funky damper spring in the middle, then just leave it. You just raised your rev limit
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
