differences in starter motors
Old Jul 14, 2006 | 09:01 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Is a 89 automatic starter the same as a standard trans one. Also what makes a 90-92 starter different from earlier ones ?
please help if you are certain about the topic of this thread, if you have pics of the starer and why there different please post them.
Old Jul 19, 2006 | 06:32 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LET’s GET STARTED
"Is a 89 automatic starter the same as a standard trans one?"
No.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Old Jul 19, 2006 | 07:24 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
No.
Happy Racing !
not sure where you get your info from but there is no difference in an 89. One part number for both transmissions... so your answer is yes they are the same for both.
Old Jul 20, 2006 | 11:55 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
On my 92 I started with a 305 and swapped to a L98 (350) and I noticed the 350 starter was bigger. (and heavier) I tried the 305 starter simply because it was smaller and it worked just fine for my 9.8 to 1 CR 350. I then got ahold of a LT1 starter which was even smaller than the 305 starter and was designed to turn over a 10.5 to 1 LT1. All of these starters bolted right up to my 92 auto and later T-56 transmissions. Hope that helps.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
milk
Aug 10, 2015 06:26 PM
