could it be the fuel?
Old Jul 16, 2006 | 02:20 PM
Silver87S.C.'s Avatar
The car has been sitting for two years and now that I want it running again I find out that the fuel pump is shot.
I put another fuel pump on it under the hood, and it works...however the car wont run for any length of time and when it starts it runs very poorly.
I'm assuming that I should drain the gas tank and start over with new gas. I think this would fix the problem.
Does anyone agree....? this car has always been a pain in my butt and this time is apparently no different.
thanks for the help
Old Jul 16, 2006 | 04:10 PM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
I had concerns about this when I put a new fuel pump in my truck. I had it 3/4 of the way filled up when the pump went out on it and it's a 32 gallon tank, also the truck sat for about 9 months before I could afford the pump and have the time to do it. The color of the gas was more red than the usual yellow so I drained it into a 55 gallon drum and capped it off to deal with it later. I talked with the local gas station owners who have been doing business since before my time and said that it takes several years for gas to begin to start breaking down. They recommended that I could just mix the old gas with new if I had any concern.
Old Jul 16, 2006 | 05:02 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
You might try just mixing some high octance gas with the old and run that tank out then fill the tank again and see how it does then.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
