what kind of piston are these?
Subscribe
Jul 16, 2006 | 10:04 PM
are these flat top pistons?...I know they are 0.30 KB silvo-lites....but is there anyway I can find out anything else about them..to maybe help me figure out the compression of the motor...they are in my 383 short block.
also the head gasket, its a felpro 1010...what thickness is it?..doesnt that help determine the compression?...the motor was suppose to be 10:1 from what Ive been told...that was with 64cc edelbrock performer heads 60899's
thanks!
Reply 0
Jul 16, 2006 | 10:10 PM
You're better off just knocking out one of the pistons and looking for a casting number or something. Then call up the manufacturer and ask.
Reply 0
Jul 16, 2006 | 10:40 PM
how hard is it topull a piston outt? what do I gotta do??....where would the casting number be?
Reply 0
Jul 16, 2006 | 11:29 PM
The 1010 is .039" compressed.
To figure out the compression, you'll need to measure how far down the hole the piston is at TDC. You can do that with a dial indicator, or a straightedge and a set of flat feeler gauges.
You'll also need to know the volume of the valve relief in the piston. You can use some plasticine and a graduated cylinder without taking a piston out.
Reply 0
Jul 17, 2006 | 08:06 PM
ok, I did the straight edge method...I turned the crank a few times to see how the piston did and I stopped at where I thought it was just before it starts to go back down...with the head gasket that is on there I was able to get .036 feelers in between...with the head gasket off I cant get anything in between the straight edge and the piston...looks like it sticks outta the cylinder just a hair....
what that tell me?
I think I need to know cause I ordered a set of heads the other day and I got AFR 195's with a 65cc combustion chamber.....and if I need to change anything on my order I need to do it now...
can some one help me out?
Reply 0
Subscribe
