Idle problems
Old Jul 17, 2006 | 09:45 PM
ineeedmorespeed's Avatar
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
Idle problems
So I just bought an '89 Z28 wiht a built 350ci TPI. Ever since I bought it there was this problem with "cold start" because after sitting it would turn over after about 5 seconds of crank time, fire up to 1500rpms, but then immediatly drop down to about 400rpms and inevitably bog out unless you gave it a little gas. After starting the car and giving it gas for 1-2 minutes the problem went away and the car start up immediatly with no idle problems...800-900rpms in P everytime.
NOW...we just upgraded plugs, wires and a distributor cap, my friend advanced the timing to about 10 degrees and the car ran fine last night. Today I went to start it and it gave me the usual cold start problem but this time it wouldn't respond to me giving it gas. It would be and on/off sort of thing...I could barely keep it idling about 400rpms and definitely can not drive it more than 10ft before it bogs out?
what do you guys think?
fuel pump...iac valve...tps valve...plugs/wires...anything?
My main concern here is $$$ to fix it. Should I be worried...other than this problem the engine runs fine.
On a side note...I upgraded to Mobil1 synthetic motor oil only to find out from the guy I bought the car from that the motor was not built for synthetic and that running it could cause problems. I've only ran it for about 50 miles but I did a couple 1/4 mile runs...could this cause any problems so soon???
thanks in advance..
Old Jul 18, 2006 | 05:11 AM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
I doubt synthetic oil is your problem. If your problem was only on cold starts, then I would say you have leaky fuel injectors, but since it is hard to stay running at all you may have low fuel pressure due to a bad fuel pump or filter. I would check your fuel pressure first and let us know what it reads. You can buy (or probably rent) a gauge from Autozone and they are easy to use.
Old Jul 19, 2006 | 11:16 PM
So my fuel gauge hasn't been working lately. I est. I had a 1/4 tank of gas Saturday night so I put $25 in and then drove about 60 miles. Within that 60 miles I did maybe 10 1/4 mile runs and a couple races on the highway. Turns out the thing simply ran out of gas!
Now the car stays running and responds to gas when I give it and idles fine (800-1100 rpms) but I still have the brief cold start problem that causes the car to want to bog out the first few minutes it runs...
I'm thinking possible IAC valve or something with the ECM that regulates a/f ratios. I'm gonna have a shop check out that problem. Should be something small being that it is not a consistent problem and the mechanics of the car seem to be fine...
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
