Ignition Coil
Old Jul 18, 2006 | 05:33 PM
xklipze's Avatar
Ignition Coil
Im installing a new ignition coil , the OEM part from checkers auto parts.
Basically i think They didnt offer me the bracket that comesd with it, because the FACTORY COIL, comes with a bracket with two pain in the A$$ rivets.. do i need to purchase a new bracket? because i dont know where to turn, i dont have a dremel etc...
basically they sold me a ignition coil, and now i cant properly install it , bvecause of lack of tools/shop....
i hope they sell a new bracket
any thoughts?
Also corrosion is located on the 8 points of inside the distributor cap... Replace ?
Old Jul 18, 2006 | 06:30 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I know you can take a wirebrush, or something similar to that effect to get the corrosion off. Or you could just spend 25$ for a cap and rotor from MSD and be sure everything's perfectly clean.
Old Jul 18, 2006 | 06:59 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Yeah I'd replace the cap. I would also replace the coil with an Accel or MSD high voltage coil, but that's just me. The OEM coil will work fine. As far as the bracket goes...you'll have to remove it from the original coil. Did the new coil come with the apporpriate bolts and nuts to attach the bracket to the coil? My MSD coil did so I would assume yours did too. I used a screwdriver and a hammer to chop off the big ends of the rivets going through the bracket, it came right off after that. A drill would work too.
Old Jul 18, 2006 | 07:48 PM
kjvail1204's Avatar
A drill accually works great, I did this not to long ago, the MSD coil comes with the bracket, or you could just use the old bracket and run new screws through the holes. Get the screws from home depot, or advaced should have something.
Old Jul 18, 2006 | 09:46 PM
xklipze's Avatar
yah my neighbor did it for me with his dremel.. worked perfect, installed and ready to do more work to the car...
I would sure like to figure out the proper way to test the egr solenoid....
any suggestions
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
