327 vs 350 question
Old Jul 18, 2006 | 11:13 PM
steve7589's Avatar
327 vs 350 question
ok i recently got a 1990 rs camaro i have a L98 350 stock motor that i could use in the car or i have a 327 shortblock bored 60 over,comp cam 280h,true roller timing set,arp bolts throught.so i have a delemma as to what motor to use.i could use the 327 and bolt on the L98 heads and then go w/a performer rpm intake,650 dp carb at least thats what im concidering which would be a better choice?what kind of hp would i be seeing in the 350 with aboved mentioned parts vs the 327 the heads are iron.thanks,steve
Old Jul 19, 2006 | 03:13 AM
ede's Avatar
ede
all else being equal the 350 will make more power
Old Jul 19, 2006 | 09:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
the L98 is a roller block, so you can easily and **cheaply** use a roller cam. Theres a giant power boost right there, plus no hassles of flat tappet cam breakage.
The .060" over motor is a little dicey too, that's a lot of meat to remove... Might make it too thin, and in the future you have nothing left to cut out again.
I'd also stay with the L98 block.
Old Jul 19, 2006 | 04:51 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I also agree. Stay with the L98 350. The 327 bored .60 over not only can you not bore it anymore any 327 or 350 I have been around that was bored .60 over had overheating problems. Not saying they all do but I have seen it.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
