Going to Order This Cam...Opinions?
Old Jul 20, 2006 | 04:44 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Now that I have the heads, it is time to order my cam, so I'm all ready for it.
I had my heart set on this cam. Is it too much for a daily driven IROC that is going to have Brodix 200cc heads on it along with a ported out TPI Intake? Going to get a prom from pcmforless.com as well. Stock motor except for exhaust otherwise:
Comp 270HR-10
Old Jul 20, 2006 | 05:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That should work well
Old Jul 20, 2006 | 07:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
IMHO there is a better cam out there if your heads can handle the lift. It is the XFI 218 cam. It has 268 degrees of advertised duration and more lift under the curve. But the one you picked will get the job done.
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
Bigold4x4
Sep 28, 2015 05:21 PM
