Ignition Switch
Old Jul 20, 2006 | 06:51 PM
xklipze's Avatar
Ignition Switch
I purchased a new ignition switch, and started lowering the steering column, if anyone has changhed the ignition switch on a 1991 camaro z28
and wants to throw me some usefull tips,...
its hard to get at, but im slowly making progress.. them PLUGS SUCK..
so i figured its connected to the dimmer switch screws also... got them out.. but now the ignition switch looks like sometyhing is connected to the very back bottom...
im kind of thinking about removing the whole steering column... but i dont wanna do surgary on my car..
let me know what you guys think...
the battery is disconnected.. but i didnt remove the air bag fuse.. u think i should if im jujst replacing the ignition switch...??
Old Jul 20, 2006 | 07:43 PM
bygblok's Avatar
once the wires are off the dimmer and ignition switches both lift off the top of the column. There are two rods, one for the dimmer, one for the ignition switch. There's a little adjustment on either and it will test your patience but if you sit back and study it for a sec it's easy to see how they both work.
Old Jul 20, 2006 | 08:10 PM
xklipze's Avatar
anyone recognize these ignition switch parts ??
Putfile <--link to picture of extra parts
After i installed it.. these were left over..(someone else took apart the car) really regret that.. didnt have much of a say though...
What does the cable that screws into the back of the ignition switch (the one which connects to the button on the shifter.. whats that do ?? wats it connect to.. anything? besides the 2 small screws on the ignition switch itself?
dimmer switch has 3 holes in it for screws... i'ds asume..
i can definitly see the front one being used.. but then the second might be tough to get in there.. it looks like a wierd angle.. and the 3rd .. is a CRAZY angle flange.. what does that connect to ?
however i do know which plugs go to which on the dimmer switch and the ignition switch...
just wondering now where the dimmer switch is connected to besides the plug...? (just the first screw hole on the steering column.. or both holes on the steering column ??
Old Jul 20, 2006 | 11:13 PM
xklipze's Avatar
dimmer switch..
im just going to connect 2 screws to the dimmer.... the first 2..
Anyone know whats not going to work with them extra pieces ?
Putfile
<a href="Putfile" target="_blank"><img src="http://f10.putfile.com/thumb/7/20023482812.jpg" alt="Click to enlarge."></a>
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
