need help Identifying Aftermarket pistons
Old Jul 22, 2006 | 09:34 AM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
Hey guys like it says. I didnt build the motor so I dont know what the other person did. This is the numbers on the Piston head.
H345NP And the .030 for the bored over.
and 249-01-12-A
Doing LT1 Heads right now and would like to know what I,m paring them with.
Old Jul 22, 2006 | 11:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Speed Pro hypereutectics.
Old Jul 22, 2006 | 11:42 AM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
OK. So are these ok or are they crap?? Never had to replace or do anything with Pistons.
Brand: Speed Pro
Product Line: Speed-Pro Hypereutectic Pistons
Bore (in): 4.030 in.
Bore (mm): 102.362mm
Piston Material: Hypereutectic aluminum
Piston Style: Flat
Compression Distance (in): 1.560 in.
Piston Head Volume (cc): +5.00cc
Valve Reliefs: Four
Wrist Pin Style: Press fit
Pin Diameter (in): 0.927 in.
Top Ring Thickness: 5/64 in.
Second Ring Thickness: 5/64 in.
Oil Ring Thickness: 3/16 in.
Quantity: Sold individually.
Piston, Hypereutectic, Flat Top, 4.030 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring Grooves, Chevy, 350, Each
Old Jul 22, 2006 | 11:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're fine for just about any kind of NA use.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
