Run then no Run.....
Old Jul 22, 2006 | 06:41 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Hello,
I just put in my new ZZ383 engine. I got the car running then I shut if off to fix a small gas leak. When I went to start it back up it would not start. I have fuel that is fer sure.
I worked on it for a few hours and If I let it sit a bit (Because it would flood) it would start and run fine. I gave up and took my Demon carb off and put on my Edlebrock. I got the car started and running good. I shut it off then went to restart it and again it would not start?.
If I get it running good and shut it off it will not restart. If I keep trying it will backfire out the exhaust or the carb then the next try it will fire.
I am using a 6AL with a CraneCam 1000-1501 Distributor with a crane coil. Using the Green/Violet wires.
Anyhelp here would be great!
Old Jul 23, 2006 | 02:41 PM
Car: 85 Z
Engine: 383
I did find the issue...... It was when I had the engine out I cleaned up all the wiring and I ran the Green/Violet wires together with all the bulkhead wiring. That was making the pickup wiring trigger at different times making it miss fire and not start. Went out this morning separated the wiring and all is good!
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
