Fan only turns on with A/C...?
Old Jul 24, 2006 | 01:26 AM
Alderon's Avatar
Well Subject says it all, My 89 Camaro 5.0L TBI electric fan will only turn on with A/C. So is there anyway to find out why it isnt turning on with Engine reaching Red Mark on Temp Gauge?
Old Jul 24, 2006 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Thermal switch in the pass side cylinder head. Also, before someone else says it: A on this site will usually provide a wealth of info.
JamesC
Old Jul 24, 2006 | 05:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
May I suggest a seperate fan controller? I've had the same problem in my 1990 TBI motor, and I've been through 3 fan switches, and one was a fancy high dollar ($85) job, and even it went out after 2000 miles.
I gave up, and went with a seperate fan controller, they range from $40 to over $250, depending on what you get - I spent $90 on a nice one from Flex-A-Lite - on at 220, off at 160, adjustable, and variable speed, with ability to add always on or always off switch. A probe inserts between the radiator fins, wiring was easy, and it ALWAYS works the right way. I'll never return to those in-the-head switches again!
You can just leave the dead fan switch in the head as a plug, install the seperate controller, and be done - no more coolant in your face to change that factory crap.
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
