valve springs
Old Jul 24, 2006 | 01:53 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
valve springs
how do i get the valve springs off without spending a trillion dollars? I can't find a good compressor to save my life.
Old Jul 24, 2006 | 02:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
heads on car or not?
I just used a cheesy one from princess auto (like harbor freight). Looks like a bit spoon almost. Nothing fancy at all. Was $3.
Old Jul 24, 2006 | 03:01 PM
how did you get them to compress and take the retainers out?
Old Jul 24, 2006 | 03:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
assuming heads are off car, and on your bench...
put the hole in the tool over your rocker stud, and put a washer, and nut over that, to hold the tool on. Then it's like a pry bar, you just pry down, and it'll open your valve, and compress your spring. So once you have that mastered, you can clamp your heads down to the table, so you aren't just prying them off the table, then put a 3/4" socket over your retainer, and whack it with a hammer. It'll just bounce back and whack you in the face, but that'll seperate your keepers from the retainers, so you aren't just pushing the valve in. Now that you are wise, put on goggles, then use the tool and compress it, and use a little magnet to remove the keepers. Then release pressure, and lift off the umbrella, and spring and you're done. You may need to put something in the chamber, so that you can hold the valve from opening, so that you're just compressing the spring. Usually the hammer whack is all it takes though.
Old Jul 24, 2006 | 03:38 PM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
Ive used the claw type, like $20 bucks from advanced auto,
has like 2 claws,and a **** on top,works well.and cheep
Old Jul 25, 2006 | 03:05 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
if the heads are off the car what I have done in the past as a quick fix was to take a deep 5/8 socket put it on the top off the spring and hit it with a hammer.it pops the retainers right off quite easily.just don't beat the hell out of it all you need is a good tap to get them loose.
Old Jul 25, 2006 | 10:15 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto. Had them off in about 5 minutes per head.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
