Head modification
Old Jul 24, 2006 | 02:24 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Head modification
Has anyone tried or had their alum. aftermarket heads drilled and tapped for center bolt valve covers, when they are perimiter form the factory (trickflow, afr,).... I seen a good deal on a set but I really want center bolts
Old Jul 24, 2006 | 07:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'd have to weld bosses in the middle of the head first.
I'm not seeing it, but hey, it would be original!
Old Jul 26, 2006 | 10:51 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have seen the kits that allow you to convert a perimeter style valve cover to a center bolt before. I saw the add in "Car Craft." I believe that the cost was $70.
Old Jul 26, 2006 | 11:30 AM
Guest
Guest
Posts: n/a
Depends on the head. I machined a set of AFR's to accept centerbolts (they were perimeter bolt heads), but I wouldnt advise following my path
If the head wasnt offered by the manufacturer as capable to use both styles, like Brodix, it wont happen unless you do some welding or use the adapters.
Old Jul 26, 2006 | 11:33 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
They sell kits to do the exact opposite center to perimeter. Not sure if you could make it work the other way around though. I know someone who used the kit to make his center bolts heads work with perimeter covers but he said he could never get them to stop leaking and ended up using the center bolt covers.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
angel2794
Sep 8, 2015 06:22 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
earlpote
Aug 28, 2015 10:42 AM
