stall
Old Jul 26, 2006 | 05:43 PM
car86cars's Avatar
stall
1986 camaro 305 tpi it stall form idle sometime it has it and sometime it don't does it hot or cold more hot than cold has new tps ,iac ,spark plugs , wire's ,fuel filter ,and rotor have put 4 mass air flow 3 used 1 new fuel pressure is @ 44 psi when key is on 38 psi @ idle
Old Jul 27, 2006 | 09:58 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If you don't have a vacuum leak you likely need to set base idle and maybe setup the TPS low/high voltages; procedures are on my site.
Also, a leaking EGR valve can cause a similar symptom.
Old Jul 29, 2006 | 08:40 PM
car86cars's Avatar
tps is set at .54 and idles at 600 rpm
Old Jul 30, 2006 | 12:54 AM
Do you detect a vacuum leak before or after it warms up?
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
