How many rpm's before I blow my a/c?
Old Jul 26, 2006 | 07:43 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I have a stock (enginewise) 92rs with an lo3 that is about to undergo an engine swap. Its a pretty stout 355 and I want to know how many rpm's can my stock a/c handle before it craps out.
Is 7000 ok?
Old Jul 26, 2006 | 08:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
uhh, flip it off before racing i'd say. I think you won't have a problem, I think theres a clutch or something to keep it from spinning too fast.
Old Jul 26, 2006 | 08:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I don't know about the R4 compressors, but I have run both the A6 and H6 styles well over 9,000 compressor RPM and not blown one. On my old 305 the crank had an 8" diameter pulley and the pulley on the H6 compressor was 4.25". That gives a 1.88:1step up (8/4.25). The EBL shut the compressor off at 5,000 engine RPM or whenever I hit PE. At 5,000 rpm not in PE (saw many times), the compressor was turning around 9,400 RPM!
The old 305 when carbed had an A6 compressor on it. The crank pulley was 6.75" and the compressor pulley was 5". That gave a 1.35:1 ratio. That compressor was used without any type of cut-off on it, other than the cycling switch (surely it cycled as the RPMs shot through the roof). I ran that engine to 6,500 rpm ALOT of times. That is around 8,800 RPM compressor speed.
A6
HR6
Here is the R4 that is on your car.
It has a 4.96" pulley on it. The crank pulley should be right at 8". I would consider 10,000 compressor RPM to be the absolute MAX.
Old Jul 26, 2006 | 08:38 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Good.. because I live in south louisiana and if I had to choose between a/c and racing, well I'ld be doing all my racing in winter!
Old Jul 27, 2006 | 01:11 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
To repeat what Sonix said...just turn it off when you plan on runnin up the rpms. Move the slider to 'OFF' and the compressor won't cycle.
Another possibility is to get some electronic device to block the signal when a certain rpm is exceeded. That would be cool, not having to think about it when your racin in the summer.
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
90formulaVortec
Sep 3, 2015 09:26 AM
