1.6 Rocker Arms
Car: 82Z28
1.6 Rocker Arms
Just wondering if there was anyway to tell what rocker arms are on my heads? Ive got a GM350HO and they came with 1.5 rockers but oddly enough Ive heard that some of these crate engines came with 1.6 rockers but were still listed as 1.5s. Is there something stamped on the rocker or anything like that that I can tell what Ive actually got?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, if you could very accurately measure the rockers (measure the distance from the center of the rod pocket to the center of the main rocker pivot, then measure the center of the rocker pivot to the spot where the rocker touches the valve stem) and divide the larger number by the smaller number, you will get either 1.5 or 1.6....
Ive heard
So whoever you "heard" that from, I'd take that person's pronouncements a little less seriously in the future.
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Well considering that GM has NEVER installed 1.6 rockers on ANY OTHER small block, I'd say it's not likely that they did so on yours..
Transmission: 4L80E/4L80E
Put a dial indicator (in the depressed position) on the valve spring retainer when the valve is fully closed, zero the indicator dial. Turn the engine over until the valve is fully open, record the dial indicator reading.
Now put the dial indicator on the pushrod side of the same rocker, repeat (the indicator will travel in the opposite direction, of course).
Divide the first result by the 2nd. You'll have your rocker arm ratio.
(You could do the same thing with a depth gage or caliper, as long as you referenced the same point on the head for the open & closed positions.)
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
GM didn't make a stamped steel 1.6 rocker. So if they're steel, they're 1.5. They did, as posted, install 1.6's on the lt4 but all of the 1.6's I've seen (gm or aftermarket) have 1.6 stamped on them.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
92rsvortec350
19
Oct 9, 2015 09:39 AM
