computer chip on a cam change?
Old Jul 26, 2006 | 11:56 PM
fg_stadium's Avatar
if I change my cam in my 91x28 305tpi to this cam would I have to change the computer chip?
Basic Operating RPM Range:
1,000-5,000 RPM
Intake Duration at 050 inch Lift:202Exhaust Duration at 050 inch Lift:212Duration at 050 inch Lift:202 int./212 exh.Advertised Intake Duration:252Advertised Exhaust Duration:264Advertised Duration:252 int./264 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.550 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.546 in.Valve Lift with Factory Rocker Arm Ratio:0.550 int./0.546 exh. liftLobe Separation (degrees):113Intake Valve Lash:0.000 in.Exhaust Valve Lash:0.000 in.Computer Controlled Compatible:YesGrind Number:252XFI HR13Quantity:Sold individually
Old Jul 27, 2006 | 02:14 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
The description answers your question: Computer Controlled Compatible:Yes
It's not a must, but it would be very beneficial to pick up a chip as well. You could see 20 extra horses, maybe more.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Bryan F
Aug 18, 2015 02:28 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
