blueish smoke when I whomp on it
Old Jul 27, 2006 | 12:34 AM
fg_stadium's Avatar
1991 z28 305tpi auto tranny,,no smoke when I start it up or drive it normal but when I get on the gas and stay on the gas a blueish smoke comes out the pipes,would that be the piston rings?
Old Jul 27, 2006 | 02:12 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I would believe it is infact piston rings.
There are two ways you can burn off oil...one way is to have it leak down from the valve seals while the engine is off, and burn it when you start the motor...but thats only smoke on startup.
The only other reason is the piston rings. You are getting on the pedal and increasing oil pressure. That pressure is going up through the worn rings. Looks like it's time for a rebuild
FormulasOnly
Jul 23, 2018 08:47 AM
gixxer92
May 18, 2017 11:20 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
