intake leak
Old Jul 28, 2006 | 08:36 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
intake leak
I recently put a has a holley street dominator intake on my car replaced the old intake it was just a stock aluminum one and it has a holley 650 dp which was on the engine before its a fresh engine just got rebuilt about 400 miles on the motor. when i got the intake on and started the motor it did not want to idle down i can turn the adjustment screw all the way out and it will still idle around 1000 rpm its running real rich i think. There also is some white smoke coming out the passenger side exhaust never did this before does this means its rich. would a vacuum leak cause this. thanks
Old Jul 29, 2006 | 01:36 PM
Vader's Avatar
A vacuum and coolant leak at the intake flange could certainly exhibit those symptoms.
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
