Engine hesitates after warm up, under load
Old Jul 30, 2006 | 07:48 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
I just changed the head gaskets. It starts right up and runs fine. But when it warms up and I put it in drive the engine gradually starts to hesitate within 30 seconds in drive it hesitates the most and stays there...until I turn it off and let it cool. Once cold it starts all over again, runs fine then hesitates. I redid the valve lash a couple times, then I changed the spark plugs, but the problem is still there... any ideas?? it doesnt hesitate if I warm it up in park and rev the engine
Old Jul 31, 2006 | 05:10 AM
anyone?
Old Jul 31, 2006 | 12:19 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Check for vacuum leaks after car is hesitating spray WD-40 around intake manifold and see if hesitation goes away. make sure all vacuum lines are attached.
Old Jul 31, 2006 | 06:09 PM
turns out I set the valve lash waaay too tight...that would explain it..runs great now
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 22, 2015 08:17 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
