one piece crank seal, or two?
Old Jul 31, 2006 | 04:23 PM
nomad88z's Avatar
bear with me, i'm an idiot.
alright, now that that's out of the way, here's my problem:
I have an 88 Iroc with a Corvette Aluminum head L98 350 under the hood. A while ago it started knocking, badly. I jacked the motor out of the mounts, and replaced all the bearings in the bottom end; rods and mains. With the pan off of it and everything disconnected, i didn't notice any severe damage to the main journals or connecting rods, so i figured bearings would solve the problem. It didn't.
Now, I'm getting ready to put a crankshaft in it, figuring that its knocking because the crank is worn out of round. My question is, is my engine a one piece seal crank or a two piece?
thanks guys
Old Jul 31, 2006 | 04:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
One piece, if it's the original engine.
Old Jul 31, 2006 | 04:35 PM
nomad88z's Avatar
thanks alot, i didn't know who else to turn to for help other than this forum.
Old Jul 31, 2006 | 04:54 PM
jr. gearhead's Avatar
Car: 83 T-Top w/ 85 Z-28 and 91 RS parts
Engine: 377 (in progress)
Transmission: 700-R4 (unless i find a t-56)
Axle/Gears: from the Z
87 was the change year for small blocks and there is an adapter to allow a 2-piece crank in a 1-piece block
Old Jul 31, 2006 | 05:31 PM
Guest
Guest
Posts: n/a
86 was the change year.
Old Jul 31, 2006 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Correct.
A new crank may not be needed. The crank you have can most likely be turned down to an undersize. Or, it may already be an undersize and putting in standard size bearings would definately cause knocking.
Old Aug 1, 2006 | 01:21 AM
sorry...86 not 87. 87 they went roller
angel2794
Sep 8, 2015 06:22 PM
Reborn756
Sep 4, 2015 03:42 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
gixxer92
Sep 1, 2015 04:32 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
