1982 305v8 LG4 info
Old Aug 1, 2006 | 09:12 PM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
1982 305v8 LG4 info
hey guys i need to know all the specs on the 82 305V8 LG4. i mean everything from cylinder heads to cfm on carb to camshaft specs. thanks guys
Old Aug 2, 2006 | 03:35 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Okay here goes 82 305 LG4
Bore and stroke--3.74 x 3.48
compression ratio--8.6:1
horsepower-- 145 at 4000rpm
Torque--240 ft lbs
camshaft--.234 intake x .257 exhaust
Thats all I could find right now!!
Old Aug 2, 2006 | 06:18 PM
Engine: 87 LG4 305
thanks man, if someone can get me intake valves size and exhaust size, cfm on the carb,
Old Aug 2, 2006 | 06:33 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
1.84 intakes 1.5 exhausts
carbs were 750 rochester q jets
if you find a petersens for 82 then it iwll list all the cam specs and pisotn weights and everything down to every final detail
did just find cam specs on l69 305s though hum
getting closer...
L69 305 H.O.
190 hp / 240 lbft
Tach: yellow 5000
red 5500
Lift: intake .410
exhaust .423
Duration: intake 320
(crank) exhaust 320
howcome you need to know this anyways
are you planning something
let us know
3rdgenparts
May 21, 2016 11:50 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
indygene
Sep 26, 2015 11:21 AM
