New To The Board(trouble code problem)
Old Aug 2, 2006 | 07:58 AM
305 black ghost's Avatar
I was doing some research and happen to run across this message board. I drive an 86 camaro v8 quad jet carb . and i am getting codes 14,15 and 32.
my radio hose busted yesterday i didnt notice this because my aftermarket guage isnt working for some reason i replaced it and while i was at it decided to do a code check and came out with those 3 codes.. and for some reason its running very sluggish... when my car over heated i was sure to pull over and replace the radiator hose...it still had antifreeze and all. anyone know what those codes mean or could i have done something wrong?
Old Aug 2, 2006 | 01:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
From the homepage, there's a FAQ link in the left column, at the bottom of that page is a trouble code link that takes you here https://www.thirdgen.org/service-eng...ht-error-codes . 14 was from overheating. 15 may be from a wet connector - it's on the thermostat housing, try drying it out. 32 is the barometric pressure sensor, may also be a wet connector, that's on the cowl above the heater/AC housing.
It needs proper engine temp and barometric pressure readings to tell the car how to run. After checking the connectors, clear the codes, if you still get an SES light, you'll have to check the codes again and probably replace a component or two.
Old Aug 2, 2006 | 03:16 PM
Hey thanks for the advice after hours of research, and just when i was about to give i see something dangling. It was a freakin spark plug wire. Soon as i plugged it in and started it it begin running excellent
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
overdriv
Aug 20, 2015 03:52 PM
