code 42, whats going on?
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
So the motor was just rebuilt with parts in sig, had it out of the shop to break the motor in, was driving around just fine, and all of a sudden it stalled, wouldnt fire back up again, after 10 minutes it started up again but for like 10 seconds then cut out.
This is a fuel issue, you can definitly tell the motor isnt getting fuel
what does this code even mean?
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Did you check the car for spark or fuel when it died?..I think you might have a bad ICM(ignition control module) after 10 minutes it cooled down enough to restart(classic signs).If that checks out then you either have a wiring problem in the ICM circuit or you may have a bad ECM..start with the easy stuff first though.Thats the path you will take...
Car: 1990 Camaro
Engine: 355ci
So the motor is getting spark, and pressure to the fuel rail, but the injectors arent pulsing
Just had a temporary chip burned for the break in, before they run it on the dyno and dial it in. Brand new motor.
What in the electrical system could cause that and throw that code?
Car ran greta for the first like 2 hours
Car: 1990 Camaro
Engine: 355ci
no then my shop might have fried my ecm
which they can freaking pay for lol, k well im going to call them in an hour when they open, if they have nothing yet ill suggest that. and post sooon.
which they can freaking pay for lol, k well im going to call them in an hour when they open, if they have nothing yet ill suggest that. and post sooon. Thread Starter
Car: 1990 Camaro
Engine: 355ci
its not the icm, they changed out the whole distributor and nothing, any other sugestions other then the ecm its self?
