305/350 ?
Old Aug 3, 2006 | 06:38 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
305/350 ?
Settle something for me please. What is the difference between a 305 & a 350? Thanks
Old Aug 3, 2006 | 06:50 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
the bore. everything is interchangeable except the pistons. however you cannot bore a 305 to a 350.
Old Aug 3, 2006 | 06:51 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
45 cubic inches.
They both have a 3.48" stroke, however....
A 350 has a 4" bore.
A 305 has a 3.735: bore.
The crank is not interchangeable. 305 cranks are balanced at a much lighter weight than 350 cranks.
Unless you're going to use ultra light pistons on the 350.
Old Aug 3, 2006 | 08:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Heads are different, too, although they will bolt on to the other.
speedy21cvb
Dec 18, 2003 11:01 AM
