question on ac
Old Aug 3, 2006 | 04:12 PM
1963impala's Avatar
question on ac
was wondering if anybody could tell me exactly where the high and low service ports are for the ac on a 92 camaro. it has a 305 if that helps. i have looked everywhere but can only seem to find one port. thanks
Old Aug 3, 2006 | 04:23 PM
Desert86Roc's Avatar
Low side port will be on the receiver/dryer (cylindrical aluminum tank next to firewall on passenger side). Your high side will be inline and have a different size port. you can do everything through the low side port if you have the right equipment.
Old Aug 3, 2006 | 07:21 PM
1963impala's Avatar
so the low side is actullay on the dryer? i thought that was it but just didnt seem right ot me. thanks
Old Aug 4, 2006 | 07:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yep, the low side port has the standard R12 fitting. It is pointing out the side of the accumulator toward the engine.
The high side port is on the line going to the evaporator. It is upright and located in the hard line next to the accumulator, toward the fender.
To put a gauge on it will need to use an adaptor for a 'posi-seal' port. I've also heard of it being called a deep well port. Basically the adaptor has a protrusion on it to reach down into the port. This type of high side port was used on '91-'93 GM cars.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
