Resistance on injectors?
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Quick question. Car has been idling funny like it's "chugging" since being pulled out a few months storage last month. It's like she ain't running on all cylinders. At low rpm as when comming to a stop she feels like she's gonna stall, and at mid range cruising along she occasionally feels like spark is cutting and stumbling / hesitating.
Recently replaced the cap, rotor, wires, plugs (NGK) with AC Delco products. The MSD coil is firing but it looks like a weak spark (any way to check the coil?) and spark is getting to all 8 cylinders. The distributor shaft looks good and so does the pick-up coil reading a reistance of .930 or so. Currently running off an MSD 6A.
The fuel pressure is steady at @ 41 psi.
However there seems to be good film of black carbon on the plug in the #8 cylinder. The resistance on injectors #1 and #8 are reading 16.3, while #3,4,5,6,7 is @ 7 and #2 is at 4.7.
Could my rough idle and hesitation be bad injectors? Shouldn't the resistance readings be fairly close across all of the resistors?
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
My reman'd gm 22# injectors were all around 17.5 ohms or so. Id also check the terminal on the coil for corrosion. There is a way to check the coil and its outlined in haynes/chilton.
Car: 1987 Iroc Z28
Thanks guys.
Ya, the pick-up coil seems to be slightly corroded at the connectors, but it is still functional and really doesn't look all that bad.
I believe my worst fears are confirmed, being, the GM service manuals for Camaro's and Firebirds I have been looking up here at the GM dealership (I'm a parts counter rep) all list resistance at a minimum of 11.7 or higher (ohms).
A couple of mechanics had pointed out the same. I've got at least 6 hovering at around 7.
I'm considering replacing all 8, and even with my discount a set of new GM injector kits from the GM warehouse for a '91 5.7 tpi will cost me @ $900 (Canadian).
I hear the GM's flow pretty good and I am really just thinking about sticking with them. I'm not sure if I should go aftermarket though.
Anyone got any suggestions?
Car: check
Engine: check
Transmission: check
Most folks go with the SVO F*rd/Bosch injectors for replacements.
RBob.
thejimsterz28
Sep 15, 2015 04:37 PM
