Unknown sensor
Old Aug 6, 2006 | 05:18 PM
icarus402001's Avatar
Unknown sensor
My car is a 92 RS with the original 305 and TBI.I replaced my starter today and I noticed a green wire with a broken connector just above. There is a sensor just above it with nothing attached. My temp indicator works, the idle kicks down correctly during warm up. Anyone know what the sensor is? My haynes manual is of little or no help.
Old Aug 6, 2006 | 06:47 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If it's at the base of the block near the starter, and not on the cylinder head, it's your knock sensor. If it's mounted in the cylinder head, it's your cooling fan switch.
Old Aug 7, 2006 | 05:18 AM
It is on the block. The wire is very mangled and the connector is more thsn likely broken off inside the sensor's collar. Is the sensor in the water jacket? I have to pull it to see the rest of the connector.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
