Harmonic Balancer question
Old Jul 30, 2006 | 01:34 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
I went to check my timing and to move it to 3*advanced.
The tab with the 12 8 4 TDC, I tried to aline the mark on the balancer with the 4* mark, but it wont stay running near 12*, but it idles smooth near the 10 0'clock position.. is my harmonic balancer off?
Old Jul 30, 2006 | 08:55 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
Bump
Old Aug 5, 2006 | 08:55 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
well, if i were to get my #1cyl at TDC, i can make a mark on my harmonic balancer that is lined up with the TDC mark on the tab, and that will still work correct?
Old Aug 5, 2006 | 09:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That will work, just make sure you locate TDC accurately.
Old Aug 6, 2006 | 01:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Are you unplugging the ESC? It's the brown/black wire just in front of your heater box.
https://www.thirdgen.org/good-timing-reading
Old Aug 6, 2006 | 05:22 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
um no.
Old Aug 6, 2006 | 05:33 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
I cant find a brown/black wire that hooks together anywhere..
Old Aug 6, 2006 | 06:11 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
Theres a white wire with a black stripe that hooks to another white with black stripe.. But im sorta clolor blind..
Old Aug 6, 2006 | 11:32 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
it should have a plug, and be the only wire connected to that plug. You need to disconnect that wire in order to get accurate timing readings.
Old Aug 7, 2006 | 06:05 AM
Car: 1988 Camaro
Axle/Gears: 2:73's
I looked thias up in my haynes manual and it says that The wire i found is the EST.. and then it says something about the ESC Module and unplugging that, and the 4 wire connector at the base of the distributor..
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
