few other little things(hopefully not big)
Old Aug 9, 2006 | 02:52 PM
fleakied's Avatar
Car: 91 camaro rs
Transmission: auto
well i just posed about the weird jerking however i just remembered a few other things.
1. i have a small oil leak but its so hard to locate i read other posts but they offered little or no help. i think it might be on the valve seal (not sure)
2.once my car upshifts i hear a slight rattling i think it might be loose bolts on my exhaust(3in flowmaster) however i heard some scary things about bad oil pumps spinning bearings.
so once i have found the leak and say it is the valve seal how hard is that to fix?
Old Aug 9, 2006 | 03:33 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Is it a leak as in you have a puddle of oil under the car, or is it losing oil and you cant see any evidence of where it is coming from?
If it is valve stem seals then it wont leave any mark and will leak oil into the cylender. Causing the car to smoke alittle when you start it.
Old Aug 9, 2006 | 03:39 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Well it is kinda hard to cipher what you are saying. No offense, but I think a middle schooler could have gotten his point across better.
Failed valve seals does not show you an oil leak as evidence but rather black or blue smoke on start up usually. Sometimes constant.
Go ahead and remove all spark plugs..
you will need to rent the following:
Valve spring compressor (I perfer the two armed claw, part number 27011 at autozone... free rental.)
and air fitting for a hose, so compressed air can give force against the valves.
obviously you will need to remove your rocker arms and push rods, get them out of the way for now... make sure you make some sort of organization try or box to ensure they go back in the correct order.
now you should be looking at some valve springs...
it is a good idea to buy new ones, i bought some from compcams for $50 bucks and were very nice...
Plug your air fitting to the first cylinder you are working on.
The claw compressor has two arms one is slightly longer than another which means it is perfect for springs... connect the arms about 3/4 the way down the spring and line up the tool and tighten... keep tighting until spring is relatively loose... then push the spring down and lightly tap the end of the valve and the valve locks should pop up, get some needle nose pliers and pull them away... loosen the compressor and the spring will pull right out with the retainers...
At this point you will be looking at a valve an oring and a valve seal...
If you started at the first valve regardless of what side you have started on the exhaust valve...
they are as follows for the heads
[ E I I E E I I E ]
The very tip of the valve there are two grooves... the top one (which is for the valve lock) and the second, which should have an oring...
pull the oring off, they are usually brittle and break right off.
Now for the valve seals... the exhaust valves have a small umbrella looking seals those pull right up, so do so.
when you go and buy parts you will have to obviously buy the seals...
there are intake seals and exhaust seals... they all come with orings too.
you will also need to buy some moly grease.
now get your exhaust seal, rub some grease inside it pretty good and the bag of seals should have a small clear valve tip cover... slide it on the end of the valve...
rub the valve steam with some light grease and slide the valve steam seal over the valve stem...all the way down. Pull the sleeve off and install an oring on the second groove.
now hopefully you bought new springs.
grab the spring and dip the top in grease and then put the retainer back on and make sure that is greased up too... put some grease on the bottom of the spring as well..
Compress the spring with the compressor... slide the spring on, take your valve locks and put a fair dab of grease inside them... this helps with installation...
the valve lock is sorta like a trapezoid... the bottom is smaller than the top.
put one half of the lock inside where the stem is and move the spring around if need be till it clicks in... same for other side.... then pull up on the spring to test it.. decompress spring and voila! you have one if 16 done... lol
the process is the same for intake valves, except they have a different style seal...
This is best of my knowledge... not saying i know much but there you go.
I have a feeling you may take this to the shop.
Old Aug 9, 2006 | 04:01 PM
fleakied's Avatar
Car: 91 camaro rs
Transmission: auto
yeah im sorry its kinda hard to explain whats going on. for the most part i do not see any evidence of dripping oil and on occasion i do see some light smoke billow out of the exhaust while i start the car but while i drive i never see smoke.
thanks for the replies
Orr89RocZ
Apr 25, 2016 08:28 AM
gixxer92
Sep 1, 2015 04:32 PM
Bob88GTA
Aug 18, 2015 03:31 PM
sreZ28
Aug 14, 2015 07:48 PM
