i need help on a lt1 asap please read
Old Aug 10, 2006 | 01:29 AM
rayrayjr2001's Avatar
ok i got the heads off and the number one piston has corrosion and is grimey i wanted to know how do i clean it up?? im replacing all the gaskets on the engine. i know the gasket was blown so it had to be gettin water in it. but again how can i clean it up??
Old Aug 10, 2006 | 02:00 AM
MAD_IROC-Z_85's Avatar
Car: '85 Iroc-Z
Engine: 355cu, 11:1, 292H, 750cfm, LT1 head
Transmission: T5 non/wc
Axle/Gears: 3.73, 7.5in 10bolt posi
Does the engine is gripped??
You'r better to removed the piston and hone that cylinder (if it is just surface corrosion), and what's up whit your ring, do they are OK, no rust and gum on! I would be sad if you where putting a few hundred dollard for a few milles
Old Aug 10, 2006 | 02:34 AM
the rings are fine the only thing is the buildup on the piston. is there like a solvent to clean it up or sumthing like that?
Old Aug 10, 2006 | 06:18 AM
Vader's Avatar
Carbon on the piston dome? A wire cup brush in a die grinder works great for cleaning that off. Or is it more than just carbon?
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
mrdevontay
Sep 2, 2015 08:04 PM
