no start problem - bad ground - Need Help!
Old Aug 10, 2006 | 11:59 PM
PAformula's Avatar
I'm having problems with my fiance's GTA. The battery is fully charged,but when you turn the key, you get nothing, not even a click. the headlights are also not functional, but the parking lights eventually turn on. What is going on here, It has to be a bad ground. The engine ground seems OK. Where is the firewall and frame ground on a '88 GTA?
Old Aug 11, 2006 | 05:50 AM
Not necessarily; although it could be.
It's a bad connection, somewhere. Could be in the positive side of the wiring as easily as the negative side.
There's a small wire that comes off of the negative battery cable at the batt terminal and hooks to the chassis. That's the main ground. There's a ground strap between the rear of the pass side head and the firewall.
Your problem sounds like a bad battery cable connection. Check the connections both at the battery terminal, and where the cable hooks to the starter.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
