Combination Comments
Old Aug 11, 2006 | 03:09 PM
85_IROCZ's Avatar
Its that time again, the old 355 in the Camaro is getting tierd. I have been putting together a game plan for this winters build and am just looking for a little input on what I have come up with.
Heres is what im planning:
383 Eagle forged rotating assem.
Keep the vortecs(206cc)
Compression is at 10.4:1
Comp XE294H
Keep the crane 1.6 Rollers
Holley Stealth Ram
58mm throttle body
30lb injectors
And a good tune
So what do you guys think? Any reccomendations good or bad are welcome. Its gonna be a learning curve for me as I am going to be takling the tuning on my own. Gonna be a chore at first. Thanks for the input guys
Old Aug 11, 2006 | 03:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
how'd you get 206cc vortecs?
someone had a link here recently all about vortecs. Very good info. The guy who worked at GM, and helped design the vortec cylinder heads posted on that forum (well, if you believe that I guess..)
Anyway, they usually show stall in the .500-.550" lift range. A cam with lower than that lift, but more duration might be worthwhile. I might recommend a crane cam with ~.490" lift, but the same large duration....Then again, 294?? That's a BIG cam, you sure you want that much duration? (street motor?)
Old Aug 14, 2006 | 10:39 AM
85_IROCZ's Avatar
I got the vortecs from Jegs.com, they are these JEGS High Performance - GM Performance Parts Cast Iron Large Port Vortec SBC Heads
Not to worried about the duration, only street time it will see is on the way to the track on the weeknds.
InfernalVortex
Apr 20, 2021 11:31 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Damon
Sep 26, 2015 04:29 PM
BWilcox
Sep 20, 2015 12:19 PM
