Idle problem
Old Aug 12, 2006 | 08:20 AM
1988 GTA 383's Avatar
Idle problem
Sometimes when the car is at idle the RPM will go from around 1500 to 800 on its own.Its not just the tach changing RPM but the motor revs as well.The motor is a 383 TPI ,LPE heads,LPE cam,accel super ram,accel 58mm,SLP tri-y headers.Thanks John
Old Aug 13, 2006 | 08:29 AM
Vader's Avatar
Custom programming?
Old Aug 14, 2006 | 07:23 AM
Yes it has a custom prom ,but I will most likely get a new one because the the cold start valve is disconnected .There was no way to mount on super ram runners.The idle problem happens when the engine is warmed after driving.
Old Aug 14, 2006 | 10:11 AM
Vader's Avatar
Make sure you check the parameters for IAC adders, idle vs. CTS, and other IAC count adders and modifiers. Its easy to enter contradictory parameters and have the idle behave erratically (don't ask how I know), but those are big RPM jumps.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
