removing ignition rotor?
Subscribe
Aug 12, 2006 | 08:44 PM
i'm replacing my cap and rotor, and i cant figure out how to get the rotor off (just the plastic piece that comes in a cap and rotor kit). by looking at the new one, it appears that it just pulls straight off, but no matter how hard i pull, it wont come off. is there some retaining mechanism that i'm overlooking? do i need to pull the entire distributor out, or should i be able to do this just by removing the cap first?
Reply 0
Aug 12, 2006 | 08:51 PM
No, it does pull straight off. If theyre real old, they tend to get stuck on the shaft. Keep tugging or try to lightly pry it up with something. I mean, the distributor shaft is metal and the rotor is plastic, so worst case scenario, you could just cut the damn thing off.
Reply 0
Aug 12, 2006 | 10:10 PM
Exactly. I had to tug like crazy on mine, I'm not sure how old it was, but it definitely put up a fight. They're SUPPOSED to just "pop" right off, but they do get stuck on there after so long.
Reply 0
Aug 14, 2006 | 01:48 PM
i finally got it off by prying it with a screwdriver. PITA!!
i noticed the metal underneath was rather rusty. i did my best to clean it real quick with PB Blaster, but didnt go crazy with it. should that be all shiny, or does a little rust not matter?
Reply 0
Aug 14, 2006 | 01:50 PM
A wee bit of rust is no biggie. Just hit it with some WD40 and then wipe it down real well with a clean rag. You might also want to put a dab of dielectric grease on it so next time it isn't so hard.
Mine pulls off real easy.
Reply 0
Aug 15, 2006 | 08:06 PM
when i run into a rotor that doesn't want to come off, i give them a good twist to shear off the little plastic guide piece inside of them & then they come right off. you do have to push out the piece of plastic from the slot in the shaft before you put the new rotor on.
i put a small dab of grease on the shaft to make it a little easier to remove the rotor next time.
Reply 0
Aug 16, 2006 | 06:59 PM
I usually just break them off. They can be a royal pain. I also remove the little metal tab on the inside of the new rotor so it doesn't also get stuck in the future.
Reply 0
Subscribe
