hypertech
Old Aug 15, 2006 | 09:11 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
hypertech
I know Hypertech chips are crap, but can they hurt performance? I put one in my car when I first got it (did not know any better) and now I have just left it in there figuring that even if it does not help much that it cant hurt it either. It was stock then, now it has a Crane 2032 cam, AFPR, LT headers, 24# inj. and the free mods.
Old Aug 15, 2006 | 09:45 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Can it hurt it? Not likely. Can it help it. Not too much there either.
Old Aug 15, 2006 | 10:09 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it depends on how much they really did to it.
generally they lower fan temps & turn up fuel & advance ignition timing which is not always a good thing.
a customer where i work at went through 4 or 5 hypercrap chips & each one had problems. he then tried jet chips & got no better, the next to last chip jet sent him had the fan on temps turned down, huge amounts of timing added everywhere & VATS turned off. he got a lot of spark knock even with 93 gas from it, i feel he was lucky he didn't damage his motor.
the last chip only had fan on temps turned down & they set the timing to less than what a stock chip runs.
with the mods you have done, i feel you should get into burning your own chips. even on a stock motor you can pick up a little performance just by fine tuning the chip by using what Grumpy says, "give the motor what it wants".
KO1
16
Oct 15, 2015 05:00 PM
NBrehm
Aug 25, 2015 11:49 PM
vortech305
Aftermarket Product Review
Mar 17, 2001 09:41 PM
85F-body
Jan 15, 2001 06:42 PM
My90Iroc
Dec 18, 2000 08:46 PM
