Oil cooler problem
Old Aug 16, 2006 | 08:17 AM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Axle/Gears: Borg Warner
Oil cooler problem
Need all of your infinite wisdom guy's. I somehow cracked this piece(SEE PIC) that sits between the oil cooler adapter and the engine block. It has been discontinued by GM. This silver disk has a pressire spring in it and is where the sandwich style cooler screews on to the block. Need to move my car ASAP any ideas on finding this thing or bypassing the whole oil cooler?
HELP.
Old Aug 16, 2006 | 09:28 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
dont see why you couldnt bypass the oil cooler. the piece you broke should be the adapter from the bloch to the filter bypass and then to the filter.
otherwise you can purshase the oil filter mounts from summit racing or jegs
Old Aug 16, 2006 | 09:41 AM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
I want to bypass don't know how. Any ideas?
Old Aug 16, 2006 | 11:03 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Isn't that the same oil filter adapter that's been on every small block since the introduction of the spin-on filter?
Old Aug 16, 2006 | 11:18 AM
Guest
Guest
Posts: n/a
When I went from oil cooler to no oil cooler, all I did was remove the cooler and replace the bolts. That part is the same, IMHO.
I bet the dealer looked up the wrong part.
Old Aug 16, 2006 | 11:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's what I'm thinking too. You should be able to find one anywhere. Your local machine shop probably has a pile of them. I probably even have a pile of them.
Old Aug 16, 2006 | 11:31 AM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
If so why can I find it? I took the peice to Chevy and Autozone noone knows what it is.
Old Aug 16, 2006 | 11:35 AM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
when you remove the adapter how do you spin on the filter to the block? Only thing left is a hole thats where I must need to put a filter adapter. Cant just remove the adapter.
Old Aug 16, 2006 | 11:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're just talking to people who have never had a reason to see one before. It's not a part that requires replacement commonly. It's not even a part that ever gets removed commonly, unless the engine is being rebuilt.
Old Aug 16, 2006 | 11:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your broken part isn't a part of the adapter, it's a part of the oil filter mount. You can't mount an oil filter or the oil cooler without it.
Old Aug 16, 2006 | 01:29 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Aperion, I agree with you. What I need is a place to find a replacement mount.
Old Aug 16, 2006 | 01:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try a machine shop or an engine rebuilder, a used one from them will be cheapest. Otherwise, I can look up the GM part number for you.
Old Aug 16, 2006 | 04:12 PM
Guest
Guest
Posts: n/a
Try this number
3952301
Old Aug 16, 2006 | 04:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the one, been in continuous production since 1968.
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
