6 or 7 or 8 inch internally balanced for 383?
Old Aug 17, 2006 | 10:59 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
does it really matter? what size is better and why?
I dont want to buy the worng one and then have to buy a different one..
just wanna do this once!
thanks guys and I hate to have so many questions.
Old Aug 17, 2006 | 11:55 AM
ede's Avatar
ede
do you have an internally balanced crank? i'd go with the larger diameter
Old Aug 17, 2006 | 11:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'll second ede's recommendation. The damper is one place where bigger is better.
Old Aug 17, 2006 | 12:35 PM
why is the damper better if larger? yeah its internally balanced....but why the larger versus the other? some people run smaller in their 383 or larger displacement motors....I do want a larger but I have a change to get a smaller 6.25 ATI..
thanks guys!
Old Aug 17, 2006 | 12:55 PM
five7kid's Avatar
The larger damper will be more efficient in damping crank vibrations. Crank vibration can actually affect cam timing, which also affects ignition timing, so damping them out contributes to more power gain than the smaller damper's lower rotating inertia will provide. It also makes for longer crank life.
This is one time when a good deal on a smaller damper probably isn't.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
83RDRACR
Mar 26, 2016 08:13 PM
Magman
Sep 13, 2015 12:14 AM
buckshot63
Sep 10, 2015 09:15 AM
scottmoyer
Sep 7, 2015 07:06 PM
