Coolant flow
Old Aug 20, 2006 | 08:58 PM
LittlejohnLJ88's Avatar
Car: 92 Camaro RS
Engine: 350 Modified
Axle/Gears: Stock
Coolant flow
My 92 RS's original 305 i understand had a reverse rotation pump, somewhere along the lines we had big problems because we routed the belt diffrently and caused it to run standard directions causing heating problems. I am in the process of droping a new GM 350 in. I am putting an electrical water pump to increase power, would standard rotation cause THIS motor to run hot or do i have to have reverse still.
Old Aug 20, 2006 | 09:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's not going to matter with an electric pump.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
