Small block advice
Old Aug 21, 2006 | 10:19 AM
Grumpy 427's Avatar
Car: 1977 camaro
Engine: 468 700 Hp 622 Tq - 1006 Hp 1000Tq
Transmission: Coan Power glide
Axle/Gears: moser 4.56
Small block advice
I have a 69 chevelle that i want to build a 350 for and need some advice on what to put in it for parts to make 325-350 HP and still keep it a pump gas daily driver. the car will have 3.08-.342 gear in the back? have not decided yet.
I got a complete 350 given to me out of an 80 chev half ton. can enough bowl work be done to the heads to accomplish what i want with a set of flat top pistons and a mild cam? or should i look for a set of vortec heads? If so what is the correct casting number.
Old Aug 21, 2006 | 02:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 80's truck heads won't cut it, or at least it will be much more difficult to get there with them. Vortecs would get there easily. I'd suggest upgraded Vortecs from sdpc2000.com, they have a kit that includes heads good to .575" lift, intake manifold, gaskets, rocker arms, and bolts for about $1000 plus shipping. With 4-valve-relief flat-tops, you'll be around 9.5-10:1 CR (probably best with pump premium), and you'll be able to use enough cam to get there without even breaking a sweat.
Old Aug 21, 2006 | 06:52 PM
Grumpy 427's Avatar
Car: 1977 camaro
Ok i will give them a look.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
