FLEX PLATE ? 153 OR 168 ?
Old Aug 22, 2006 | 06:54 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
can someone please tell me witch one came stock on a 92 350 ? diong final engin assembly and bought flexplate witch came in as 168. so now i just bought a new starter and it came in for a 153
so now i need them to match, any advantages or disadvanteges between 168 and 153 ?
thanks in advance, im down to the last few things to finish this build (started in december) and am really anxious to run this pig
Old Aug 22, 2006 | 09:31 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
oh shoot, I forget now.
I think the 153 is referred to as the 305 size, and the 168 is commonly called the 168 size.
Is your block drilled for both starter styles? if not you don't have a lot of choice.
Try a search, I know this gets talked about a lot...
FWIW -> I used my flywheel from my 305 (153?), and I couldn't use the larger style since my T10 bellhousing wouldn't allow it. I also had a 350 block with only mounting holes for a 350 starter, putting me between a rock and a hard place. I just hand drilled and tapped the block for the 305 starter bolt pattern, and used the flywheel from the 305.
Old Aug 22, 2006 | 10:56 AM
If you have a 92 block, it should have the bolt pattern for either.
You'll probably have less trouble with header clearance and such things if you use the smaller (12.8", 153-tooth) setup.
Unfortunately the stock starter for these cars for the 12.8" size is a downsized version of the old direct-drive Stone Age relic Delco starter that's been giving everybody fits for years. A gear reduction mini-starter, either an aftermarket one or an AC/Delco such as the one for LT1, is a VAST improvement. I highly recommend ditching the stock one and upgrading to a better one.
Old Aug 22, 2006 | 03:08 PM
SPIKE's Avatar
Car: 86 CAMARO
thanks. so i should upgrade to a ministarter. no problem. most of the ones i was looking at say for 153 and 168 teeth, they have 4 mounting holes. am i assuming right ? my block has 3 holes the two across from eachother, and one inboard closest to front of motor. make sence ?
Old Aug 22, 2006 | 08:13 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
never seen a starter nose that had anything but two holes in it
on the block mounted ones anyways
thats odd,
Old Aug 23, 2006 | 12:47 AM
Right, you'd use the 2 "outboard" holes for the 12.8". Your block has both bolt patterns.
codeysabatini
Nov 10, 2015 04:07 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
