new motor locked at 1500 rpm idle
Old Aug 22, 2006 | 06:18 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Okay ive tried timing my motor now like 10 times and it just wont seem to idle or not run like a pile of crap
I tried timing it today at 6deg btdc and when i do that it either revs to 1500 as an idle speed, or drops to around 400 rpm and chugs there for 10 seconds then stalls. I checked the TPS and its fine. I know that valvelash needs to be set as there are a few loud ones but i cant set it if its at 1500rpm shooting oil at me
So anyone have any ideas what it could be?
thanks
Old Aug 22, 2006 | 07:04 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
What's your fuel pressure when it's doing this?
Old Aug 22, 2006 | 08:04 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
42 psi +/- 1
Old Aug 22, 2006 | 08:16 PM
Is this motor a fresh rebuild? Is it a roller block or a flat tappet block? One thing I've seen occur that can cause those symptoms is a dirty or dysfunctional MAF sensor. Take a look at it, and if it looks dirty, clean it up. If there's too much soot in the sensor, it may not be sending a proper signal to the ECM and could cause improper fuel metering. Another thing: can you get a fuel pressure reading when it's "chugging"? Does the engine do this at different timing settings? Are you unplugging the advance wire to set your timing?
Old Aug 22, 2006 | 09:00 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Its a fresh rebuilt flat tappet
I checked the maf screen and it looks clean,
The first time i attempted to time it i disconnected the wrong wire, but since have disconnected the esc wire
Ill have to get a second person with me to watch my fuel pressure tomorow
thanks for the help
Old Aug 22, 2006 | 09:21 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
1500 RPM means you are getting way too much air. This can either be due to a vacuum leak, high min idle air setting, or your IAC is stuck open. Either way, fix this before looking at anything else.
Old Aug 22, 2006 | 11:01 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you by chance have that vacuum gauge?
you might need one. high idle speed, running rough, and in ability to run at lower rpms without dying is a very good indication of a vacuum leak.
just curious have you actually drove the car yet? how does it drive if you have done so?
Old Aug 23, 2006 | 12:16 AM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Unfortunately I havent been able to drive it yet, but tomorow ill go out and get a vacuum gauge,
thanks for the help, ill keep everyone posted
Old Aug 28, 2006 | 11:23 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
okay, Just as many of you suggested it was indeed a massive vacuum leak.
The cheap gasket between the upper and lower stealth ram intake was damaged
Thanks for the help all
Old Aug 29, 2006 | 10:14 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
glad all is well now
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
perZ
Aug 15, 2015 01:17 PM
