manually turnin over engine//
Old Aug 24, 2006 | 05:19 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
hey guys my engine is on its stand.. now i need to install my fuel pump.. but the push rod is in its ways... wats an easy way to turn over the motor with out the starter?
Old Aug 24, 2006 | 05:30 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
put a socket with a breaker bar on the main pulley and turn it
AC's Avatar
AC
Car: Used to drive a camaro
85, I used (3) bolts in the balancer then used the lug wrench the car came with to turn it over. If you want to do fast, multiple spins than this isn't the way for you.
Old Aug 25, 2006 | 06:11 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
This isn't a highly suggested way to go about this. You run too much of a risk of stripping that bolt in the crank snout. Ask me, I already had this happen to me before.
I would suggest looking in summit racings tool section. They have a tool for turning the crank with and without the balancer. I have always had luck turning the balancer or flexplate by hand if the plugs are out. Kinda hard to do when engine if fully assembled.
Old Aug 26, 2006 | 07:08 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
take the plugs out and turn it by hand,might still be hard but better than stripping it
Old Aug 26, 2006 | 09:50 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
When installing the pushrod, some wheel bearing grease or vaseline around it to hold it in place should keep it out of the way when installing the pump no matter where the cam lobe is.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
