plug recommendations for a 383
Old Aug 30, 2006 | 08:12 PM
kammi10's Avatar
Car: 1989 camaro
what plugs should i run on a 383 with dart pro 1 aluminum heads.
Old Aug 30, 2006 | 08:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Ones that spark.
How about some more info?
Compression ratio, forced induction or not, cam size, nitrous or not, altitude (if it's not in the "norm"), gas you're using, etc.
Old Aug 30, 2006 | 09:24 PM
kammi10's Avatar
Car: 1989 camaro
Originally Posted by Sonix
Ones that spark.
comp ratio- 9.3
no forced induction
cam is a cran saturday night special. i believe something leik 484 496 lift
no nitrous
93 octane fuel
Old Sep 2, 2006 | 02:17 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
I would start with R44ts Rapid fire A/C's If you like your radio!
Old Sep 2, 2006 | 11:56 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I dont know how much reach your heads require so I'm basing plugs off what I ran. With that super low compression and fact you have aluminum heads, you have no choice but to run the hottest plug you can get per manufacturer for your heads....why did you go sooo low in compression with aluminum heads? even with a super tight cam with factory spec duration your losing out on alot of power due to heat disappaction and not being able to keep the chamber "hot enough" so for practical purposes your essentially running a 8.3:1 compression.
Not sure if your really going to be happy, since it's surely not going to be making nearly the power it could've with a better combination.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
