Oil mysteriously disappearing.
Old Aug 31, 2006 | 12:11 PM
Brian Murray's Avatar
Car: '91 Pontiac Firebird
Engine: 4-bolt 350 TBI w/ Holley ProJection
Axle/Gears: 3.08, 10bolt
Yeah, at a rate of a whole quart every 2 hours of running.
No apparent leaks on the outside of the engine, no oil in the coolant, no coolant in the oil, it just... disappears... I can smell it burning off, but I have no idea where it's going.
This is Castrol SynTec 10w30 in my 4-bolt 350 with a whole 17k miles on it. Any ideas?
Old Aug 31, 2006 | 12:20 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Have you changed the intake lately?
I had that problem before with a different engine and it was my intake gaskets leaking from the inside. They allowed the engine to suck a lot of oil from the lifter valley straight into the intake ports!!
Good luck finding your problem!!
Old Aug 31, 2006 | 12:21 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Valve covers, oil pressure switch?
Old Aug 31, 2006 | 12:33 PM
You know... I did... lol
Hopefully I can rectify the problem by just tightening down the bolts...
Thanks for your insight!
Valve Covers/OP switch aren't leaking. No visible leaks.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
