my car is burning coolant.....
Old Sep 1, 2006 | 05:37 PM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
i cant seem to figure out whats wrong with my car, its burning coolant cause i can see it coming out of the exhaust and i can smell it too, my car really overheated the other day pretty bad when it pushed the coolant back into the resevoir and it started boiling out the top, but when it cooled down and i started it again it started puffing coolant out of the exhaust and i can smell it from under the hood somewhere, i dont want to drive it until i figure out whats wrong with it.
whats wrong with it?
Old Sep 1, 2006 | 05:47 PM
calobs87irocz's Avatar
Car: 87 Iroc Z, 70 & 71 Camaros, 79 Z-28
Engine: 350TPI, 350, 355, 355
Transmission: 700R4, TH350, TH350, TH350
Axle/Gears: BW3.27, 4.10, 3.73, don't know yet
You probably blew a head gasket.
Old Sep 1, 2006 | 05:50 PM
i sure hope so cause some people were telling me the head could be cracked and if so im just gonna scrap my car or sell it
Old Sep 1, 2006 | 08:37 PM
It's possible. I wouldn't scrap the car over a head. You should be able to pick up a good pair cheap. If you're going to go to the trouble of changing head gaskets, an extra $100 or shouldn't be too bad. But if you do scrap it, let me know where you're located. I might need some parts. Where are you located and what engine do you have? I have a set of heads off of an 87 305tpi motor that ran great. They're 081 castings.
Old Sep 1, 2006 | 08:39 PM
its a 350 TPI
Old Sep 2, 2006 | 12:29 AM
You should be able to pick up a set of heads for around $100 in useable condition that you could just put on the engine and run them. I wouldn't be too worried about it. A spun bearing or something like that is a lot worse. Besides, it's probably an 80% chance that it is just the head gasket.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
