high idle
Old Sep 2, 2006 | 04:10 AM
bahrstool's Avatar
high idle
here's my problem. when i start my car it idles around 900rpm for 4-5sec then jumps up to 1,500-2,000rpm depending on the day. ive replaced almost ALL the sensors and the computer isn't popping any codes. i have set, reset, and reset the timing, haven't been able to fnd any vacuum leaks. everything seems to be where it needs to. anyone have any ideas?
1986 T/A TPI 305
Old Sep 2, 2006 | 07:30 AM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
Has the idle screw on the throttle body been turned for some reason?
Old Sep 2, 2006 | 09:40 AM
bahrstool's Avatar
as far as i know it hasn't. i checked that by turning it a hair each way and it didn't change anything. i also just started having a problem getting the timing set. ive hand cranked the motor to top dead center. in the books it says to disconnect a plug but it doesn't show which one or where it is.
Old Sep 2, 2006 | 12:28 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
#1 plug
On a V8 - drivers side, front of engine
On a V6 - pasenger side, front of engine
Old Sep 2, 2006 | 03:00 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
this might sound kinda dumb,but is your gas peddle caught in the floor mat?
Old Sep 2, 2006 | 10:36 PM
bahrstool's Avatar
i dont have floor mats. i know which cylinder is #1. i'll reset everything and i can't get t to start. i just bought a computer-less distributor. im hoping that will fix my timing issue. as far as the idle are there any sensors that can be adjusted?
Old Sep 4, 2006 | 04:16 PM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
check the distributor rotor, cause i had a similar problem it was idling at about 1200 and it brought it down to about 550, i think it was that :S
Old Sep 4, 2006 | 05:47 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
You need to disconnect the EST connector to properly set your timing. IIRC, it's a tan single-wire connector, somewhere around the passenger side strut tower. If your timing is too high, it will cause a high idle, and it will ping under load.
Some other causes are improperly adjusted idle stop-screw, as well as incorrect TPS setting, if you have an adjustable TPS sensor.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
