Quick question about Valve Cover Leak
Old Sep 3, 2006 | 06:33 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I'm running taller then stock valve cover that are chrome with a breather cap on both sides of the engine. I have a TPI setup (speed density) and I'm not using the PCV valve(to plenum) or air port on the passenger side of the throttle body.
So, my valve covers are leaking in the rear on both sides. They are both brand new and made of some sort of teflon or something. Cost like $30 for both of them. Could this be from no PCV valve?? I figured that the oil breather caps would allow enough pressure to be released.
Old Sep 3, 2006 | 07:26 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Are they leaking oil out of the breathers?
Or are they leaking where the valve cover meets the head?
Old Sep 3, 2006 | 08:33 PM
techno101's Avatar
Car: 1989 Camaro RS
They are leaking from the seal/gasket towards the rear of the head.
Old Sep 3, 2006 | 09:57 PM
Engine: 350 4BBL
Has nothing to do with blowby or crankcase venting (although we should talk about not using a PCV system).
Check the valve cover/gasket/mounting hardware. Probably will be the new valve covers mounting surface not being planar (ie: not flat).
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
mustangman65_79
Aug 8, 2015 01:18 AM
