EMISSIONS QUESTION
Old Sep 4, 2006 | 10:55 AM
l98S10's Avatar
EMISSIONS QUESTION
I have 87 gta 350 TPI it has no air pump,no cats no air valves but it still has vapor canister and EGR hooked up. So my question is do i need them hooked up or can I eliminate them?
Old Sep 4, 2006 | 11:58 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
It would be advisable to keep both of those systems in. Basically the EVAP canister saves you gas without hurting performance, and the EGR saves your engine without hurting performance. The EGR only works during basic crusing, not 1/4 mile runs or WOT. For more information, do a search on either of those topics. If you must remove them, its a pretty straightforward procedure. Just make sure both are disabled in your ECM.
InfinityShade
Feb 21, 2016 01:29 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
